Hi SJH,
Regarding EStop: EStop is not intended to be recoverable. It
kills/aborts everything immediately and leaves things in an
unpredictable state. It is up to the operator to re-initialize and
start from a valid new line of GCode. I suppose we might add some
sort of warning if the Operator attempts to resume from some line of
GCode other than the beginning of a file. There is a "Set Next
Line" option that may help in some cases.
However Halt should perform an immediate Feedhold, decelerate to a
stop in a controlled manner along the path, and be resume-able with
no issue. The Axes should remain enabled. Could you change or add
a Halt button to your system to be used in those cases?
Regarding Closed Loop Scales: I think using Halt instead of EStop
should solve this problem. But what you might do additionally is
modify how your axes are enabled as well. Normally after an axis
has been disabled the axis might have been moved manually or coasted
to a new position so the last Dest (servo target command position)
can not be left the same as this could result in a violent jump back
to this position. Instead the current Encoder Position is used as
the new Dest which avoids any violent jump. So what you might do
instead is check whether the current Encoder Position is "close" to
the last Dest. If so, then it is safe to Enable the axis to the
last Dest, otherwise Enable the axis to the Encoder Position.
The following g-code
subroutine shows a
problem if there is
an estop in the
blocks with no
explicit G1. When
resuming, it does
not backtrack to
determine that the
motion mode was G1.
Instead, it thinks
it was G0 so the
remaining moves are
done at rapid (!)
until it sees the
next G1.
f1000
g53
g0 z0
x0
y0
m98
p100 L100
g53
g0 z0
m2
o100
g1
z100
x10
y10
x0
y0
g0
z110
m99
If I put an explicit G1 on the moves in the
subroutine, then it recovers OK. Although I have
it coded as a subroutine here, the same behavior
is observed for "straight-line" code.
Our Estop input is a hardware switch on the kflop,
which we use to disable axes, which is picked up by
KMotionCNC as usual.
On a related note, we use linear feedback scales,
which makes the estop recovery a little unpredictable:
sometimes the dialog pops up, sometimes not. I think
this might be because the scales may randomly move a
few um - if the coordinates are not exactly the same
then the resume dialog will pop up. Maybe there needs
to be a parameter to allow a bit of axis movement so
that the dialog does not pop up unless there is
definite movement from the halted position.
We also had a bad crash last night (which is why we
are looking at this in detail). Same deal, running a
program which does a lot of drill cycles with 5-axis
(indexing) mode. We used the estop to halt the
program, then I accidentally hit cycle start (where I
actually intended to rewind the program). Rather than
just resuming the program, it appeared to restart the
program anyway, but everything was scrambled.
Although we have a g53 Z safe move at the start of the
program, it seemed to skip over that and went straight
to zeroing the A,B axes. Of course, the drill was
right near the workpiece at that point, so it got
smashed up.
Unfortunately, that program is rather complex so I
can't reproduce it. It also has probing cycles, so it
is not practical to run "in the air". But I did
notice a few times that running the above snippet
would behave oddly (including seeming to run from the
start) but I can't reproduce the behavior.
SJH
